looking for a couple 350c parts
I am hoping someone on here has a couple small parts I am looking for, 1- the side guides/rub plates that the blade frame is guided by, they are held on by one of the three bolts that hold the nose on. 2-both left and right hyd. line clamps near the front of the dozer, each holds two lines with a pinch bolt through the middle and a anchor hole for rigid mounting. 3-the air dam tin with the rubber flap that goes up front and the grill holds it in place. would rather give my money to a fellow forum member, after all the help and guidance.
