Good afternoon,
The manual gives the method for aligning the flywheel and putting the bolt in the hole in the flywheel but I was wondering:
With the tranny off the back and a pump off the front, what method would you use to roll the engine to line up the flywheel?
Would you loosen the injectors to make it easier to turn over?
Thanks,
DB
450B engine valve adjustment- rolling over the engine?
Users browsing this forum: No registered users and 194 guests
