350 screaching noise in reverse
bomber
Post by bomber » Tue Sep 20, 2016 4:32 pm
I have a straight 350 loader (reverser) that has developed a metal on metal screech only in reverse. The noise is speed dependent, not RPM and seems to be coming from the rear.
There is no noise in any forward speed, it is most noticeable in first gear, less in second and third.
Any guesses on what I need to look at?
Post by Lavoy » Wed Sep 21, 2016 8:25 am
Countershaft bearing fail would be my guess.
bomber
Post by bomber » Thu Sep 22, 2016 11:27 am
Is the countershaft in the reverser?
This noise is coming from the very back of the loader.
Post by Lavoy » Thu Sep 22, 2016 4:13 pm
I'm sorry, read "reverser" and thought that is where the noise is. Look at the sprockets and see if they are hitting against the rear roller. If so, final drive bearings are out. Or even if not hitting, bearings could still be out. Try and pry on the sprocket with a large bar and see if you get any movement.
bomber
Post by bomber » Fri Nov 18, 2016 5:28 pm
The verdict is in, bad barring in the transmission. Had them all replaced ($3300).
Almost doubled the cost of the loader.
As Stan says "No such thing as a cheap crawler"
