350B
- gregjo1948
350B
To check fluid level for the reverser--is the dip stick under the right foot thru the floor board? Is it checked engine off or running? If that is the correct dip stick to use-- the level is low. Where will the fluid go to allow it to be low? This is a basket case that was apart when I purchased it so, I'm a bit lost for info for previous problems. Thanks, gregjo1948
- gregjo1948
jsal wrote:engine off dip stick sitting on threads
Thanks for reply. It is low enough that it doesn't show on dip stick. Where would the fluid have gone. Besides out the front seal, could it get into the tranny?
It is likely leaking onto the ground or into your belly pans. Top it up and keep checking under. My 350b has needed new fluid cooling lines to the rad but also has had the canister oil filter in front of the rad come loose and leak a few times.
backhoe attachment.
backhoe attachment.
- gregjo1948
No belly pans with it and no spot on floor. Haven't added fluid yet to dip stick mark so, maybe it's completely dry or not full enough to run out the shaft seals. I'll be adding fluid soon and fine out. gregjo1948Scottyb wrote:It is likely leaking onto the ground or into your belly pans. Top it up and keep checking under. My 350b has needed new fluid cooling lines to the rad but also has had the canister oil filter in front of the rad come loose and leak a few times.
Yeah. Like British sports/race cars: If there ain't no oil under 'em, there ain't no oil in 'em!
I recall there are weep holes for the spaces between the cases. They have a cotter pin in the hole to wiggle to clear the dirt so they can weep....and they like to clog....
Users browsing this forum: No registered users and 99 guests
