420c will not roll in neutral
Fixurup
Post by Fixurup » Sun Nov 27, 2016 8:30 pm
Hi, I have a 420. I just pulled the motor off to rebuild it. I went to pull the crawler and it rolled about 3 ft and stopped rolling. I then pulled it the other way and it rolled back to where it was sitting previously and stopped rolling again. This crawler has been sitting in the same spot outside for about a year. Does anyone have an idea what it could be locking up the tracks?
Post by Stan Disbrow » Mon Nov 28, 2016 5:46 am
Rusted pins and bushings in the tracks themselves.
Post by Lavoy » Mon Nov 28, 2016 10:08 am
Does it feel like a mechanical stop, like something is broken, or just something binding in the tracks?
Fixurup
Post by Fixurup » Mon Nov 28, 2016 10:12 am
It will roll about 3 feet easily then it just stops rolling sounds like something catching. I put new bushings and pins in the tracks a few years ago. So there is no play in the tracks.
Post by Stan Disbrow » Mon Nov 28, 2016 2:07 pm
Which means it is more likely that the ones on the ground froze up from sitting. Less clearance makes for easier rust-up....
I never keep these outside without a roof over them and boards under them.
Fixurup
Post by Fixurup » Mon Nov 28, 2016 2:28 pm
Thanks guys. I will check the tracks and let you know what I find.
Fixurup
Post by Fixurup » Tue Nov 29, 2016 6:59 pm
Hello, I wanted to say thanks for the help. It was the tracks just rusted up. We got them freed up and it now rolls. Thanks again.
shinnery
Post by shinnery » Tue Nov 29, 2016 7:24 pm
Always glad to hear back when a solution was found, even if I was not part of the discussion.
Post by Stan Disbrow » Tue Nov 29, 2016 7:25 pm
It is amazing how just a little rust works like a big wheel chock on these things.....
Users browsing this forum: No registered users and 295 guests
