Look mom no more pulling pins on the 6410 blade.
- Jd450/6-way
- 420 crawler
Last edited by Jd450/6-way on Mon Aug 14, 2017 10:54 am, edited 13 times in total.
WoW! Stefan, very impressive!
Very inspiring. I could probably do something like that with my 350. What did you use for hydraulic controls?
Good work!!
Good work!!
1952 MC
1965 JD350 outside blade
1968 JD350 Drott 4 in 1
1965ish 710 green tractor
1978 212 garden tractor
2003 F525 circus mower
- Jd450/6-way
- 420 crawler
- stretch44875
- 40C crawler
This looks great and has inspired me to do this to my 2010 Do you find having the angle cylinders mounted at a steep angle inboard like you do gives you enough power to walk the dozer back with the blade if you were to get in some sticky stuff
I was thinking of using a longer cylinder mounted further out on the blade and back further on the lift frame but then worry about protection from trees and etc
- Jd450/6-way
- 420 crawler
- CuttingEdge
That is sweet. I have an inside 6 way on my 350, but I am not sure that it is as robust as your set up. It is also worn out so I like your line boring methods. I might have to rig something similar up.
I might machine my own Expander style pins too though. I am not sure. That is the problem when you are a fabricator/welder, you can do about anything it is just "do I really have the time too?" That is the issue.
- Jd450/6-way
- 420 crawler
Thanks. I think 3 1/2" bore would work good on a JD 350 or similar size machine.
My machine will lose traction or stall out before the relief valve opens while pushing from the ends of the blade.
The main pivot was all egg shaped so I up sized it to 2" and the pivot for the tilt is also 2" now with grease fittings. The pins for the cylinders are 1 1/4".
I had to cut the pin bushings off of the angle cylinders and clock them 90° so the fittings would be pointing up.
It took alot of coffee and time to figure it all out lol.
- Jd450/6-way
- 420 crawler
Re: Look mom no more pulling pins on the 6410 blade.
Here's some home Reno videos.
one way to meet your neighbors.
https://youtu.be/va8tBG2ZK9s,
https://youtu.be/Dt3awlsTYWY,
https://youtu.be/lwROwpj5Kr8,
https://youtu.be/A-lw2PjyVB4,
- Jd450/6-way
- 420 crawler
[quote=Jd450/6-way post_id=64919 time=1502730993 user_id=4432]
Here's some videos of working with it around the house.
[/quote]
[/quote]
- Jd450/6-way
- 420 crawler
[/quote]
[/quote]
[/quote]
[/quote]
Users browsing this forum: No registered users and 111 guests
