re..jd40 vs jd40s whld three point interchange?*move tojd40v
dtoots1
Post by dtoots1 » Thu Jan 26, 2017 3:55 pm
would it b e feasible to take 3 point of wheeled jd40s and put on jd40 crawler to use brush hog on? how much involved????? would it be exact fit?
NEW ADDITION.....jt ritchard and others on DEBUG ERROR pages 2 and 3....move your comments to the post on jd40 vs whld...please
gus
Post by gus » Thu Jan 26, 2017 6:04 pm
yes, but not a bolt on, much work involved. do a search
Post by Lavoy » Thu Jan 26, 2017 6:04 pm
Short answer is no, completely different concept.
gus
Post by gus » Thu Jan 26, 2017 6:05 pm
tried full answer and hit "debug", preventing it
gus
Post by gus » Thu Jan 26, 2017 6:06 pm
tons of work really different.
dtoots1
Post by dtoots1 » Thu Jan 26, 2017 8:54 pm
figgers....crap
but thanks
Post by Stan Disbrow » Fri Jan 27, 2017 5:14 am
The main difference is the wheel tractor is meant to lift only. The crawler is meant to both lift and push down. And the down is with more force than the lift. So, everything is heavier and mounted completely different.
Post by Stan Disbrow » Fri Jan 27, 2017 5:20 am
The tractor rockshaft has the hyd under the seat. The crawler uses a ram cylinder on the fender. I never saw it tried, but it seems to me that if you mounted the tractor rockshaft, the hyd nose would interfere with the steering levers.
Post by Stan Disbrow » Fri Jan 27, 2017 5:21 am
At one time, I had a 430w parts tractor I used to restore a 420w. I took a quick look at maybe using the 430w 3pt on my 420c so I could move away from a towed brush hog to a mounted one. The quick look told me not to bother.
Three posts to workaround De Bug
gus
Post by gus » Fri Jan 27, 2017 2:49 pm
Search 4 yrs back full photos of it, 3 pt build
gus
Post by gus » Fri Jan 27, 2017 3:12 pm
Stan Disbrow wrote:Hi,
I did put the cyl under the seat and do have down pressure
gus
Post by gus » Fri Jan 27, 2017 4:42 pm
search 3pt, mar 2012, gus
dtoots1
Post by dtoots1 » Fri Jan 27, 2017 4:50 pm
wow...sure would be nice to have a 3 pt though....
well i aint going to try that.
i sure like the jd440 i am looking at with 6way hydraulics and in very good shape......just puts me at my limits....dozer at 6380 plus 1500 blade = 7880lbs
for 1500 $ diff between the jd40 dozer, i want the 440
will advise when i get it settled.
thanks
dtoots1
gus
Post by gus » Sun Jan 29, 2017 2:49 pm
28 posts? are some not showing up?
Post by Stan Disbrow » Sun Jan 29, 2017 2:58 pm
Every time someone sees Debug Mode, there is a blank post generated. All it does is increment the post counter.
If you see Debug Mode or No Posts Exist, you have to close your browser and start over. Or you will wind up stuck unable to post....,
On threads with more than one page, start on page one, then scroll down to read new posts. At the end, you can go to the next page. If there are more posts, keep on going. When you hit No Posts Exist, close your browser and start over.
I have no idea what in heck caused this, but I am slowly finding workarounds...
Users browsing this forum: No registered users and 378 guests
