Winch fix
Winch fix
Hi I am new my son and i have Goten a bei 440 we got. it. going and now we are going Go fix the winch any advice would be apreciated also if any one Knows Howe to get a manual could you Tell me
440ic
- Paul Buhler
Just wanted to up date we have gotten it mostly apart had many broken bolts and the clutch and Break were welded to the drum The break adjustment nut will not come out I think I will have to cut it It is so rusted I can not tell what it should be Our plan is when the new bearings come we will put the drum back in and put the side covers on then we can use the dozer well we find or make the rest of the parts
440ic
- Paul Buhler
Hi:
I think Lavoy has those brake adjustment nuts. If you can take your winch off the machine and go at it on a bench, I think that getting your old adjuster out of its fused situation will be easier. Others may have some thoughts on this too. Good luck. Paul
Adjusters suck when they are stuck. I have new ones on hand, find a tap and clean up the threads once you get it out, that helps tremendously.
Users browsing this forum: No registered users and 294 guests
