I decided to rebuild both my integral cylinders and now it's been months since I took them apart and I forgot how I can index them. In the past it's been one at a time but now I am at a bit of a loss.
Anyone point me in the right direction so to speak.
Kevin
Indexing Integral MC Cylinder
Re: Indexing Integral MC Cylinder
11 degrees from level sticks in my head, but can't remember for sure. I think the MC service manual has the correct procedure.
I'm also thinking that if you draw a line though the lift shaft bar pointing forward (towards the end with the four bolts), the travel has to be between the top and bottom of the cylinder ends. I have the MC manual and I don't see that anywhere. I guess I need the manual for the integral cylinder only I've never seen one. I have the parts list...
I was wrong, it is 16 degrees from level, pointing up with the piston at the end for maximum up.
That was it. Just slightly up from level did the trick.
Good, glad it worked out, they can be a pain.
Users browsing this forum: No registered users and 141 guests
