2010 Crawler Engine
ironyetty
2010 Crawler Engine
Post by ironyetty » Wed Oct 18, 2006 6:54 pm
I recently found out why my 2010 was using water, turns out the head was cracked and the gasket had blown. Now I am stuck with a delima? I found a repaired head for $750 and have already bought all the gaskets to replace but on the other hand I found a guy who says he has a gas motor out of a combine that will work for $750.
Can anyone tell me what would be my best bet to go ahead and fix the head on the diesel or put a gas motor in.
How does the gas motor run and does it have comparable power to the diesel?
Thanks in advance,
Cliff
Post by Lavoy » Wed Oct 18, 2006 8:14 pm
The gas will not have the torque of the diesel. Additionally, you will need a lot more than just an engine, you may need radiator, most likely will need a different exhaust manifold, hood, fuel lines, throttle linkage, and a few other things that I can not think of right now. It is not a simple throw it in deal, it will take some work, and a gas parts crawler to rob stuff off of.
Users browsing this forum: No registered users and 237 guests
