to access the Q&A section...where you find the new pic server info and access to register....you have to be logged in to the jdcrawlers site just like you do to post a new topic etc... once registered you can then access the pic server and add photos.
many may not have seen the message relating to the new picture server since you have to be logged in to view the Q&A message board to see it...the Q&A message board is at the bottom of the "Board index"
thanks
dtoots1
re....posting pics
re....posting pics
Re: re....posting pics
O.K.
we do have our OWN pic server....see above post to get to it and register to be enabled to post your pics....
have posted several things to watch for in entering pics to post on the forum. Am working on getting direct link back to forum from the pic server to make travel between the two much easier. Will continue to post additional info on the pic server forum posting where you are able to sign up...am using the editor to try to keep everything in one posting for easy reference...the edit does NOT show up as a new post message so will have to watch it for any changes. eventually i expect to edit some of the extraneous info out to shorten the post.
keep in mind this is a work in progress...there are several things that will be changed or added as this is developed. want to keep as simple as possible for everyone to use.
Users browsing this forum: No registered users and 178 guests
