Here is the clutch control arm that I made. The one for the left side was broken and I couldn't find another one. John Deere wanted $200.00 for this little arm. So i made one here is the pictures of it. I haven't installed the linkage on left side. Dry fitting. I also had to lengthen the adjusting bolt. Did not have enough adjustment to adjust by manual, cut the original threads off, as it was 3/8 x 32 TPI NS. No one had National Standard (NS) bolts or nuts, and didn't even know what NS was. So I welded on a 3/8 NF cap screw and re-threaded the adjustable end to 3/8 NF. Seems to work great. I did both sides so they will be the same. Have clutch and brakes adjusted on both sides.
This is the right side, original clutch control arm, which was in good shape. this is what I used as pattern to make one for left side. And you can see where I welded the new 3/8 x 24 NF bolt to the solid end.
1010 clutch and brake controls
Users browsing this forum: No registered users and 132 guests
