2010 c Combustion Chamber and nozzle
ironyetty
Post by ironyetty » Wed Oct 25, 2006 2:37 pm
I just bought a new head for my 2010 crawler and the outfit I bought it from already had put new seals and everything for the combustion chamber together. However the chamber setup is the later model 2010 chambers, the one I took off was the earlier of the two. Will the injector lines fit the new chamber setup? I know the injector assembly is different but can't tell from the manual if the hook up is the same?
Thanks in advance
Cliff
Post by Lavoy » Wed Oct 25, 2006 3:05 pm
I believe they are different, but wounldn't swear to it.
jdman
Post by jdman » Fri Oct 27, 2006 9:15 am
Yes, There Different....... 10001-42000 Is A Two Piece Line.... Cyl #1 Part # at13730t #2 at13729t #3 at13732t #4 at13731t Then You Need 4 # t11291t 42001 - up Is One Piece.. #1 at17170t #2 at17171t #3 at17172t #4 at17173t.....
Jeff
Users browsing this forum: No registered users and 161 guests
