Locate by Area
RacinJason
Locate by Area
Post by RacinJason » Wed Jun 06, 2018 8:23 am
I wonder if there is a way to search for members nearby on this forum. Ie, a filter, similar to the one for members names?
JD 112, JD 420 C
Re: Locate by Area
Post by Lavoy » Wed Jun 06, 2018 9:21 am
Not that I know of. You can put location in your profile so people can see it, that is about it.
Re: Locate by Area
Post by Stan Disbrow » Wed Jun 06, 2018 2:51 pm
It doesn't exist as the board is set up. It could be added. Need to enable it in the 'search by custom profile' field.
If you hit 'members' in the 'board index' field at the bottom of any page, you will see all the data fields in the members list. The location field is there. Near the top is 'find a member', and you click on that to bring up the search screen. You can search by Username, Joined Date, Post Count and Rank. Not by Location. But, that can be added to the list. It just is not right now.
Have: '58 JD 420c 5-roller w/62 inside manual blade
Have: '78 JD350C w/6310 outside manual blade
Also Have: 1950 M, 2005 x495, 2008 5103 (now known as 5045D)
Users browsing this forum: No registered users and 32 guests
