well folks someone here aught to know...my 6 volt starter every once in while seems to have a dead spot or maybe my bendix aint kicking back properly.
is dead stick like no juice and i know battery up and good. usually i have to pull starter and spin by hand and play with bendix, put er back in and will start her up for another long time, sometimes a year or more...starter has been gone thru at shop. been running all day and i stalled it and it finally kicked over started ran couple seconds quit and now dead....
will bendix give no juice symptom or is that simply dead spot?
thanks
6 volt starter problem
- gregjo1948
Re: 6 volt starter problem
Maybe solenoid problem or bad wire that, when moved a little, affects whether it works or not.
Hi dtoots1,
It sounds electrical to me unless your starter is jamming into the flywheel and locking it up. Is your starter still the original style with the pull rod to a switch on the starter? If so check the contacts in the switch and on the starter. Its and easy check to start with. Those get eroded from the arcing when they contact and can act up intermittently. Try cleaning the contacts on both. If they are too badly eroded you may need to replace the switch and starter stud. Wear in the linkage can affect getting a full throw and contact as well.
Some folks have had the starter stud changed to a threaded stud when they had trouble and added a remote mounted electric solenoid in place of the mechanical switch , when they had this problem.
You might have a dead spot in the starter, but I would start with the switch and starter contacts.
As usual n the blamed thing....
first of all i actually had ma deere electric shop check her out about 2 years ago, they actually did replace that copper stud/contact and cleaned her up...would you believe $5.00????? and yes that was the problem then...
Now, i just pulled it this morning, pulled the 1 countersunk mounting pin, played around turning armature by hand and bendix a bit, hooked up jumper cables, found out 1 leg of cable no good, then cleaned all contacts made sure stud locking nut tite then switched to the good cable and starter kicks over, reinstall and kicks right over.
Now that left me still not knowing why, can only assume bad contact at some point...the counter sunk mounting bolt does accumulate some rust which i cleaned and of course all the contact points including battery posts.
all good until next adventure!!!
So just for info, if a dead spot in starter...can that be fixed or require another starter? ocourse aint going to find another armature or field if that where dead spot is either..
thanks guys
thanks guys
- Paul Buhler
Glad you were able to fix your starter. I've had to take apart my switch twice over the years. As you found, the copper contacts will gall and/ or misalign. That switch was probably my first repair on my machine, and one of the least expensive
. Best wishes. Paul
Users browsing this forum: No registered users and 272 guests
