40c shifter
fundytides
40c shifter
Post by fundytides » Tue Sep 10, 2019 10:31 am
While working today, shifter stopped working. Transmission was in 2nd and working ok but couldn't shift out of gear. I removed the cover and as I had expected, end of shift lever had slipped out of the notch in the fork. I will disassemble per the factory manual and repair/replace whatever is worn and check all balls and springs. Is there anything special that I should watch for or any special tricks that any of you have learned in doing this work. Any advice is appreciated.
original possum
Re: 40c shifter
Post by original possum » Tue Sep 10, 2019 1:19 pm
Unless you are trying to keep it "original" you can replace the whole cover with a "caged" shifter off a 420 4 speed. Some interference with clutch handles going into one gear (fourth as I recall) but reliably finds all the gears, including first!
Re: 40c shifter
Post by Lavoy » Tue Sep 10, 2019 3:24 pm
As a general rule, what bothers is the "bearing" which is not a bearing, but that is what they call it. Remove the shift lever and check the wear in the slot. Repair and damage that you see there. Check the stud in the shift cover that goes in the slot in the shifter, often times it is loose or worn, replace as necessary. Replace the "bearing" and snap ring on the shift lever. Many times you can double up the snap ring which make the shifter a little stiff, but they shift so much nicer.
fundytides
Re: 40c shifter
Post by fundytides » Tue Sep 10, 2019 5:13 pm
Thanks for the input. Stud in shifter cover looks good. I will replace bearing and double up on lock ring if necessary. I will also check detent balls and springs tomorrow as it appears that they are not working as they should on the 2nd and reverse shaft.
fundytides
Re: 40c shifter
Post by fundytides » Thu Sep 12, 2019 7:50 am
Found a broken spring in the 2nd/rev. shifter. Don't see any other major wear. All interlocks and the other detents work well. I will replace the shift lever bearing as well. If I use a second snap ring as suggested by Lavoy, where will I place it?
Re: 40c shifter
Post by Lavoy » Thu Sep 12, 2019 10:24 am
On top of the first one, it puts a little more down pressure the shifter ball. Just did one yesterday, works good.
fundytides
Re: 40c shifter
Post by fundytides » Sun Sep 15, 2019 7:35 am
Lavoy, when you say to install the second clip on top of the first one, what holds it in place. I don't think 2 will fit in the groove but maybe I am wrong. Thanks
Re: 40c shifter
Post by Lavoy » Mon Sep 16, 2019 8:18 am
Same groove as the first one, it fits.
fundytides
Re: 40c shifter
Post by fundytides » Mon Sep 16, 2019 6:13 pm
Thanks Lavoy. I will try assembling it tomorrow. I'll let you know how it goes.
Re: 40c shifter
Post by Lavoy » Tue Sep 17, 2019 8:16 am
They can be tight, but never had one not go. It will make the shifter stiff, but it will wear in in time. Grease the cup the shifter sits in, and then grease the top of the shifter ball before you put the bearing back in.
fundytides
Re: 40c shifter
Post by fundytides » Tue Sep 17, 2019 9:40 am
What's the trick to riveting in the pin in the shifter tower. I used a small bolt as a jack inside the tower and tried to rivet the outside end over with a hammer and drift but afraid to hit it to hard. Don't want to break the casting
Re: 40c shifter
Post by Lavoy » Wed Sep 18, 2019 8:08 am
I have kind of given up on riveting them. I put the shifter in place, find a small enough screwdriver that will sit in the slot and wedge the pin in place. Then I bronze the pin in place. Otherwise they just seem to loosen up again.
fundytides
Re: 40c shifter
Post by fundytides » Wed Sep 18, 2019 9:29 am
OK. Thanks.
fundytides
Re: 40c shifter
Post by fundytides » Mon Sep 23, 2019 2:46 pm
Everything back together and working well. New detent spring and ball for second gear, shifter bearing, snap rind and pin. A little tricky getting the shifter forks to drop into the grooves on the gears but worked on the 3rd try. Changed transmission fluid (pretty milky). Amazing how much moisture is absorbed over time. Will change final drives fluid, engine oil and filter and maybe hydraulic fluid and then back to work. Oh yeah, I have to remove the hood and fasten the gas tank down again. Bolts must have vibrated loose as it is moving around and has dropped enough that gas cap is hard to get on and I'm worried that the tank might hit the battery cable. Upward and onward! Thanks Lavoy for your usual good advice.
Users browsing this forum: No registered users and 83 guests
