420C alive again!!
chickenman
420C alive again!!
Post by chickenman » Thu Dec 07, 2006 1:05 pm
After having to put in new propeelr shaft, replace center housing, rebuild carb, and a few other things my'56 420C is now back alive. Pushed some scrap iron into a pile at friend's garage with it yesterday. Still have to put a few things such as grille, bellypan and grille protector back on as well as new seals in hyd. cylinders and then repaint. Can't decide if I want to paint it JD Green and Yellow or go back with the industrial Yellow that Miss. Forestry Comission had it painted. Any thoughts?
Howard Yoder
Post by Howard Yoder » Thu Dec 07, 2006 5:26 pm
If it came from the factory yellow then I would put it back to yellow just my 2 cents worth
chickenman
Post by chickenman » Thu Dec 07, 2006 6:36 pm
It was green under about three coats of industrial yellow. The JD decals and "420" was under the yellow --on the green which makes me think it came from the factory JD green. It is early'56 which did not have the yellow strip down the hood.
ggfossen
Post by ggfossen » Thu Dec 07, 2006 7:50 pm
Chicken Man,
I know exactly how you are feeling. I'm only slightly ahead of you in the resurrection process, also a '56 420c. I'm still finding things that need fixed, but I do find myself riding around on it with sort of a smug expression. Coupled with my 4600 with loader, they make a pretty good little toy construction outfit. Then again, I am just sort of playing around.
Congratulations.
Gary
whybill
Post by whybill » Thu Dec 07, 2006 10:24 pm
Good evenin and I also have an early 420 mine is also painted industrial yellow by the Alabama forestry folks. One of these days I intend to give the old girl a new dress and I think that I will give her back her original colors..... you can see the original paint comming through the yellow in lots of places now. just my thoughts.
Bill
Bill 420c dozer 5 roller
N. E. Alabama
older is better just keep it greased
hunter41mag
Post by hunter41mag » Fri Dec 08, 2006 5:18 pm
Chicken Man,
Congrats on having it moving again!
If it can be determined I would go with what was originally on it from the factory. Will keep the value up for down the road.
Don
Eastern PA
440IC
JimAnderson
420 color
Post by JimAnderson » Fri Dec 08, 2006 7:07 pm
chickenman.
A good way to find out what color the machine came from the
factory with is to contact the John Deere Two cylinder club.If you
give them the serial number they for a modest fee will provide you
with what amounts to a build sheet for that machine.This includes
basic specs like number of rollers ,pad width,optional equipment
and color.I had them do my 430s and for about $15.00 each got
the build specs for them.It is nice to know just how they came
from the plant.JimAnderson
chickenman
Post by chickenman » Fri Dec 08, 2006 8:50 pm
Thanks for the suggestion Jim, but one problem--no serial number. I know from the location of the missing plate it is below 100,001, which makes it eary '56. Working with JD to trace original number from some other numbers on it. Looks like I will have to get those verified by a JD territoral mgr., notarized and some othe things. May get complicated.
Users browsing this forum: No registered users and 103 guests
