What outside/ inside diameter size do I need?
I'm doing the system pressure checks.
350 BE
196047t
shims for reverser
- Jason37756
Re: shims for reverser
What part number are you looking for? I'll check to see if the dimensions show when I check your number.
- Jason37756
Forgot I had a parts book...
T15858t .060 thickness
T14587t .024 thickness
I done a pressure test on the clutch oil regulator valve....it was only 45 psi.
Shim T14587T became T14587. T14587 is .406" ID, .748" OD, .024" thick and material shows as steel. Looks like they may still be available at about $13.50 each. However, the online parts catalog shows M3048T as the current part number, with this note: "REMARKS (SUB FOR T14587, THIS APPLICATION)". M3048T is .344" ID, .750" OD and .024" thick, and material is shown as A4-11 (about $2.25 each).
Washer (not shim) T15858T became T15858. T15858 is .266" ID, .750" OD, .060" thick and material is shown as steel (about $27.50 each).
The suffix letter has been removed from most part numbers, as noted above. If you use the online catalogs and search for one like your T14587T it will come up as "No Results Found". Drop the suffix and it comes up as valid. Just FYI, if you haven't encountered that yet.
- Jason37756
Thanks for the info Jim!
I wonder how much an .024 shim will help the pressure. I'm currently getting 45 psi for the clutch oil regulator valve.
Jason
Jason
Users browsing this forum: No registered users and 282 guests
