Injector return line hose size?
Anyone know what size hose is intended to fit the tee on the injector line that returns to the tank? Fitting measure around .200-.210 but not really a standard size. I had a short piece of VW 5mm is hose left over that fits well.
Re: Injector return line hose size?
It looks like the JD part number is R68281 for the bulk hose used to make those fuel return hoses. It says it has an ID of 0.156" (5/32") or 4mm. Any hose used needs to be rated for fuel oil service. Pressure will be minimal as it is an open return to the tank.
Users browsing this forum: Google [Bot] and 92 guests
