My uncle dropped off his 550G with pedal steer. The right pedal does not return all the way up like the left side. If I pull the pedal up, about 2+-", the arm in the floor maybe moves 1/16” - 1/8”. Does this just need a simple linkage adjustment? Or is this a problem with the valve body not returning to neutral?
Also, this is my first time driving a pedal steer. Should I be able to steer with full power or only when the decelerator pedal is pressed? I do not know what is correct or does it need work. So far, I see no track slippage but that does not mean that the clutches are not rusted in place.
JD 550G TD pedal steer
