440 ic Power
ironyetty
440 ic Power
Post by ironyetty » Mon Feb 05, 2007 6:09 pm
I was just curious what kind of horse power the 440 ic gas motor has?
Also the dozer was sitting for quite some time before I bought it and the gas has turned to varnish, whats the best way to go about getting all this cleaned out so I can try and fire it up to see what I got?
Thanks in Advance
Ironyetty
whybill
Post by whybill » Mon Feb 05, 2007 7:35 pm
Clean the tank and fuel lines also replace the filter and clean the sediment bowl if it has one...............Go ahead and rebuild the carberator. it will need it.....also If I were in your place I would change all the fluids just to checl for water in the oil and oil in the water........ no sense in wrecking the engine when there might not be much wrong......
Just what I would do. I would use paint thiner to clean the tank and lines then rinse with fresh gas.
Lots of luck
Bill
Bill 420c dozer 5 roller
N. E. Alabama
older is better just keep it greased
Post by Lavoy » Mon Feb 05, 2007 7:42 pm
The first 440's were 30HP, when the diesels came out, the gassers got bumped up to 33HP, this is the flywheel HP, not PTO.
Users browsing this forum: No registered users and 92 guests
