timmtnman
Post
by timmtnman » Tue Oct 03, 2023 4:38 pm
I am looking for the rear mounting brackets and bar that the belly pan attaches to if anyone has one available. This dozer has a winch also. Thanks
Post
by Jim B » Tue Oct 03, 2023 4:56 pm
Best I can say is look up the part numbers and use the part search function on the JD Parts web site to see what other models might have used the same parts. Then it is start searching the web and salvage yards using the part numbers, same as for the radiator shroud you were looking for. If you haven't used the part search, it is the same page as the model search for a parts catalog. Click the box that says Model search and you will get a drop down with a part number, click that to set the search for the part number and enter your part number instead of a model. Read carefully as it will show models with a part that might have a digit more than the number you are searching for.
timmtnman
Post
by timmtnman » Tue Oct 03, 2023 5:53 pm
Jim, I looked for the part and part numbers and was unable to find them on jd parts site.
Post
by Jim B » Tue Oct 03, 2023 7:14 pm
Look at section 15 Equipment Attaching, the drawbar page. I believe you are looking for the crossbar and it's mounts used with the regular drawbar for a crawler without a winch.
timmtnman
Post
by timmtnman » Wed Oct 04, 2023 10:14 am
Thanks Jim
Users browsing this forum: No registered users and 129 guests
