40c Roller interference
fundytides
Post by fundytides » Fri Sep 19, 2025 2:51 pm
Problem with one of my tracks. It's a 4 roller 40c and one rear roller is interfering with the sprocket on that side. This was a derelict tractor that I purchased years ago and ran more or less successfully for several years. Last year I put a new to me used track on one side and decided to replace the non-original rollers on that side with the correct ones. The rollers that I removed were much smaller diameter than the original rollers. I also rebushed the front idler. It now appears that the rear roller is catching on the sprocket. It looks like it is too close as there is no room for a safety block. Do I just drill new holes in the frame assembly and move the roller ahead enough to clear or is this going to create other problems.I haven't done any measuirements yet but suspect that whoever installed the non-original rollers may have changed the frame as well. Not sure if I can drill the new holes while the frame and track is in place or do I have to drop the complete frame assembly and move it out from under the tractor to drill it? Any suggestions are appreciated.
gus
Re: 40c Roller interference
Post by gus » Fri Sep 19, 2025 5:15 pm
Did you look or feel for other holes? Might be another set ahead more.
fundytides
Post by fundytides » Fri Sep 19, 2025 8:06 pm
No such luck! That would be an easy solution.
Post by Lavoy » Sun Sep 21, 2025 4:37 pm
Roller shot, bearings out of the final drive, or someone has replaced the tapered nuts in the side frames with regular nuts, and it has pounded the holes out and allowed the track frame to come back. Regardless, moving the roller is not the answer if there is a much more severe problem causing it, or there is a simpler fix.
fundytides
Post by fundytides » Mon Sep 22, 2025 6:47 am
Thanks for the suggestions Lavoy. Roller bearings are ok and new oil seals Will check main drive bearing and holes and tapered nuts in frame.
fundytides
Post by fundytides » Mon Sep 22, 2025 12:54 pm
Hi Lavoy, just took a quick look at the side frame. The rear bracket on the side I am having trouble with looks like it has had an amatuer welder attach the rear bracket to the frame and it has broken away again.Guess it's time to drop the frame and have the brackets welded properly. Were they originally riveted? Are the tapered nuts you are referring to used to attach the rear of the frame to studs on the casting? Looks like flat nuts on mine in this location. What is the best way to correctly determine the proper location of the rear bracket on the frame? Finally, it looks like the dozer blade that is on my crawler is contributing to my problems. It is loosely mounted to the crossmembers and free to move around quite a bit. Another indicator of a problem is that there has been no safety block on this side and when I tried to install one after I installed new rollers and track, the safety block would not fit between the cross farme and the sproket. What a mess. Any info or advice is greatly appreciated.
fundytides
Post by fundytides » Wed Sep 24, 2025 1:39 pm
Took the rear fender off today so I could get a better look at the side frame. As I mentioned before, it looks like someone tried, not very sucessfuly, to weld the bracket that the cross frame bolts to, back on to the side frame. The area of the side frame, that the bracket was originally riveted to, is completely broken away which looks like it has allowed the crossmember to move back and down. This is probably why my 4th roller is hitting against the rear sprocket, Unless I am told differently, it looks like I should remove the side frame and repair that area and reattach the bracket, Two questions: Is it ok to weld the bracket to the side frame instead of using rivets as original and how do I make sure that I locate the bracket correctly. Also, what is the best way to support the rest of the machine while I take the side frame (and the track assembly) off?
gus
Post by gus » Wed Sep 24, 2025 2:08 pm
Personally, I would look for a good side frame. It will be aligned and spaced exactly right.
fundytides
Post by fundytides » Wed Sep 24, 2025 3:46 pm
Pretty rare in this area. Not many of these old crawlers or parts for them available. Shipping from the US, Trump duties/tarriffs and the exchange rate make the cost of thigs like this pretty prohibitive.
Post by Lavoy » Thu Sep 25, 2025 8:48 am
Yes, you can weld them, but I would put bolts in all of the rivet holes, and then just use a couple short stitches to prevent movement.
fundytides
Post by fundytides » Thu Sep 25, 2025 10:33 am
Thanks lavoy. I will follow your advice. Don't know how much of the rivet holes are left, hopefully enough to locate the plate properly and I will use bolts and weld as suggested. The plate looks like it haas taken quite a beating over the years and also tore a piece ouf the sideframe where the plate was mounted. From what I have seen in parts sheets that I have looked at, the dozer mounted on my crawler is a No. 61 Angling Bulldozer. Seems to me that the method used to mount these units must put a lot of stress on the crossmembers and the side frames. Maybe that is what tore the bracket off on mine and maybe forced the trackframe rearward. Anyway, I will do my best to repair the damage and get all the moving parts back where they belong. My grandson is a welder and does a lot of work on heavy equipment so I am sure he will keep me on the right track and do whatever welding is required.
Post by Lavoy » Thu Sep 25, 2025 4:17 pm
As long as crossbar clamps are tight, and the dozer mounting clamps are tight, should not have caused any damage. Not having the correct tapered nuts or something else in the sideframe where it mounts to the cutch housings is what I have seen the most.
fundytides
Post by fundytides » Thu Sep 25, 2025 4:54 pm
Crossbar clamps are tight. Regular nuts, or bolts, attaching side frame to clutch housing. All dozer mounting clamps are loose and just floating around. Also, all pivot points on the dozer are very worn and sloppy. Lots of work to do here.
fundytides
Post by fundytides » Tue Nov 18, 2025 10:04 am
Just an update on my progress with my side frame problem. Finally got the side frame removed from the tractor and damage is about what I expected. Both brackets have obviously been worked on before with lots of weld of questionable quality fastening them to the side frame along with various size bolts in place of the original rivets. Front bracket looks ok with the excetion that it pulled away from the bottom lip of the sideframe or wasn't positioned properly the last time it was worked on. Rear bracket also has been "welded" and various size bolts used in place of the rivets. Top end of bracket containing the two rivet/bolt holes has broken off and most bolt holes are wallowed out. My plan is to reposition both brackets so that the rivet/bolt holes line up, redrill the holes and install new bolts of cosistant size. I will then have the broken bracket rewelded and both brackets rewelded to the side frame. Does this sound like a reasonable approach?
I also noticed that there are no threads in the clutch housing holes where the frame attaches. I believe that originally there were supposed to be studs in these holes to attach tapered nuts to hold the frame on. The hole in the frame are not tapered so perhaps the holes are just worn from regular bolts and nuts being used the last time someone worked on it. Should I just drill the frame and housing to an appropriate size to eliminate wear and to take an appropriate nut and should thne frame be welded to the housing to avoid future movement? The crawler is only used occasionaly for hobby projects so won't be subject to a lot of hard use.
All comments and suggestions are appreciated.
Post by Lavoy » Tue Nov 18, 2025 3:59 pm
You can drill the holes in the clutch housings to 9/16 NF, and get the correct tapered nuts to put back on and that part will be fixed.
Users browsing this forum: No registered users and 230 guests
