Jd 450 clutch adjustment problem
georgia088
Post by georgia088 » Wed Nov 12, 2025 12:52 pm
I have a “parts” crawler jd450 straight. It has been sitting for over a year with a bad clutch. It is actually in better shape than the one I’ve been workin on. So, I decided to try and fix it.
I took engine out and sure enough the clutch was frozen to flywheel, but it was completely broken from the spline. So, I replaced it.
Got it back together and I’m at my first problem. I am trying to make the adjustment On the clutch pedal as the manual states, but I can’t get the 3-3/4” of free play with the pedal before adjusting the 1/2” jam nut in the bell housing.
I don’t understand why. If I tightrn the 3/4 bolt on the pedal it bottoms out and the end of the bolt contacts the Clevis type linkage. If I loosen the bolt, it simply becomes loose. And there is a gap between the head of the bolt and the pedal stop, but the free play remains the same. About 1” of free play before you can feel the throw out bearing contact the pressure plate. I need to increase the free play quite a bit.
Is it possible the 1/2” jam nut adjustment inside bell housing is so bad out of adjustment that it could prevent the free play adjustment from reaching the 3-3/4” as the manual states?
Which way should I be turning the 3/4” bolt to add free play to the pedal and make the stroke of the HLR longer before the throw out bearing presses against the pressure plate, clockwise or counterclockwise?
I am fairly certain the adjustment of the HLR is causing problems. The machine will move but with little to no power. If I slightly press the clutch down it pulls harder with more power. This seems to me the hydraulic pressure is increasing but if I continue to press the pedal, the clutch decouples the motor from the transmission and removes all power.
Any help as usual is appreciated!
Thanks!
LeonardL
Re: Jd 450 clutch adjustment problem
Post by LeonardL » Sun Nov 16, 2025 9:53 am
So it has been forever plus three days since I last worked on one of these 450 clutch / HLR's. But as I recall there are two things that could be your issue. The first is the pressure plate for the engine clutch. They should be set with a gauge?? I think!! Like I said it has been well over twenty five years since I last worked on one of these. But I do remember having one that the pressure plate was not right at the fingers and it caused everything else to be wrong.
The second thing is I think the HLR needs to be backed way off before you adjust the engine clutch. Do the engine clutch and then the HLR.
I know I'm not being of much help here. But I hate seeing a question go unanswered. So hopefully this will help little.
Users browsing this forum: No registered users and 163 guests
