350B WINCH instal with no pto lever
Dan Moore
Post by Dan Moore » Fri Nov 28, 2025 1:48 pm
Im trying to find out how I can put a winch on a 350B that doesnt have a pto control lever.
Re: 350B WINCH instal with no pto lever
Post by Jim B » Fri Nov 28, 2025 6:26 pm
Welcome to the Boards.
What are you trying to install for a winch? The 350B used the JD model 3315 power winch. Does your 350B have a power shaft already installed and sticking out the back of the crawler? If it does have a shaft, is it the winch power shaft (it has a short splined outer end) or a PTO power shaft (This one has a common 1-3/8", 6 spline PTO end)? The winch power shaft is not disconnected with a lever like a PTO. The winch power shaft turns all the time as the 3315 winch is a self-contained (it has its own internal hydraulic pump) hydraulically operated winch.
Post by Stan Disbrow » Sat Nov 29, 2025 9:42 am
If your 350 does not have the winch power shaft already, then you will have to acquire the necessary internal parts and install them into the transmission. Not an easy task. Especially as these machines are built around the transmission.
Dan Moore
Post by Dan Moore » Sat Nov 29, 2025 6:44 pm
I realize what winch I need, I have no shaft sticking out the back and no lever to disengage the shaft. Every 350 Ive had with a winch you could disengage the shaft. Is a 350 B different? Can I just put a shaft in from the back? Is the coupling in there for the shaft to go into? Thanks Dan
Post by Jim B » Sat Nov 29, 2025 8:09 pm
I don't have direct knowledge of the 350B but in looking at the parts catalogs it does appear the B needs the PTO control lever and related parts like the straight 350. The winch drive shaft and the PTO shaft were different, but they used the same shaft and control arrangement in the transmission to drive the outer shafts. The 350C was where the option of a winch power shaft drive without the lever and related parts the PTO needs started, as the shaft was different in the transmission when no control lever was used.
Looking inside your transmission is the best way to tell for certain what is missing or already in there.
Post by Stan Disbrow » Sun Nov 30, 2025 8:49 am
Edit: I see in the prior post that the Straight and B used the same drive for both the PTO and Winch. I had a C with the winch drive and the manuals show the two use different parts. So, what follows is for the C and the D. The part about the shaft length and splines still apply.
There is no control lever for the Winch shaft. It turns all the time. The control is on the winch itself.
There is a control lever for the PTO shaft. And the PTO shaft won't drive the winch.
The Winch shaft sicks out from the rear a slight distance. The PTO shaft sticks out a much longer way. And the splines are very different.
Adding either one means getting down into the heart of the transmission. To pull the trans, the engine, reverser and both final drives have to come off. It's not an easy job. I recall helping my Dad do this for a few JD350 crawlers when I was a kid. I can't say as I would ever want to do this again. Well, if I had to get into a trans for another reason, then I would add such. Provided I could get the parts these days.
rhbarsto
Post by rhbarsto » Fri Dec 05, 2025 1:53 pm
I am confused. If the 350b does have the PTO lever but no external shaft can a shaft be installed for winch without major overhaul?
LeonardL
Post by LeonardL » Fri Dec 05, 2025 4:29 pm
Yes... if the lever is there then all you need is the shaft assembly. On some models you could install the shaft assembly even if there was no lever. The difference is you can't turn them off since there is no lever with a slider inside the transmission. In other words the shaft will spin all the time. Thats why they have a cover to go over them if you don't have a winch or other implement installed.
The latter of the two styles were used with winches that had the capability of turning on and off within the winch unit itself. Thus eliminating the need for the PTO lever and slider.
You can drain the oil out of the transmission, remover the small cover at the bottom left corner on the transmission rear cover. Then you can look inside the case to see if you have the shaft with the splined end on it to accept the PTO shaft. If you don't see a splined end on the shaft then you will need to go inside to replace that shaft.
Not all 350s came with PTO capability. From the straight 350s through the B's, C's, and D's. It all depends on how they were ordered originally. PTO was considered to be an option.
Hope this helps!!
LeonardL
Post by LeonardL » Fri Dec 05, 2025 4:36 pm
Just and FYI... I need to add that if you have a reverser then your PTO will not function if the reverser is in neutral. The 350 PTO is driven by transmission gearing and it is powered by the reverser. It may try to turn a little bit just from the friction that is inherent in the drive line. But put it under any load it will stop.
Post by Lavoy » Sat Dec 06, 2025 10:12 am
Referencing specifically straight and B model 350s, whether the crawler has a PTO lever or not does not matter. ALL 350's of these series could have either a PTO shaft, or a winch shaft. If you had a winch crawler, it has a winch shaft, simple as that. If you want to add a winch to a bare or PTO equipped machine, you will need a winch drive shaft and bearing cover.
Users browsing this forum: No registered users and 201 guests
