Keeping upper idler rollers lubricated
towntw
Post by towntw » Sat Apr 25, 2026 9:22 am
I'm starting work on the 1955 40C I bought last fall. First item before driving it around much is that one of the upper idler rollers was frozen up.
I removed the idler, arm and all. Once I had the cap and thrust plate off, it started rolling. But it was dry and full of dirt.
Here is my conundrum. The early five-roller crawlers had a solid roller and a grease fitting at the end of the shaft in which grease could be pumped. The later five-roller crawlers had no grease fitting, but in the roller itself had an opening with a screw-in plug. You'd remove the plug, fill with 90W or 140W oil, then screw the plug back in. It appears in my case, I may have an early roller (no plug) installed on a late assembly (no grease plug).
The roller is otherwise in good shape (no flat spot), so I don't think it had been seized long.
Any recommendations on how I should move forward with this? I could potentially drill/tap an opening and make a plug, if that makes sense to do.
Re: Keeping upper idler rollers lubricated
Post by Lavoy » Sun Apr 26, 2026 12:59 pm
Early idlers had a 1/8" npt fill plug, next generation, one of the cover bolt holes is driller all the way through, and you put oil in that way.
towntw
Post by towntw » Sun Apr 26, 2026 6:30 pm
I'll look for that. Thanks!
Users browsing this forum: No registered users and 111 guests
