jimmydiesel
Post
by jimmydiesel » Thu Jul 09, 2026 11:42 pm
I got this 440 in June of 2022. It was tired but with some adjustments and a handful of minor repairs it has been a work horse.
The clutch had started slipping so out came the engine.
When the engine separated from the bell housing about a quart of engine oil poured out. The drain hole was plugged up with a piece of a cut off bolt and oil sludge.
The engine wasn’t using much oil (especially for a Detroit) so it appears the rear seal has a slow leak that couldn’t drain out the bottom
and built up inside the housing. Check those drain holes.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
sweeperman
Post
by sweeperman » Thu Jul 16, 2026 3:07 pm
nice engine hoist
jimmydiesel
Post
by jimmydiesel » Fri Jul 17, 2026 4:39 pm
sweeperman wrote: ↑Thu Jul 16, 2026 3:07 pm
nice engine hoist
Thanks.
It is the most used pice of equipment I have.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post
by jimmydiesel » Sat Jul 18, 2026 10:50 pm
New front and rear crankshaft seals, new camshaft and balance shaft seals.
New clutch,release and pilot bearings.
New friction disk’s for the throttle control.
New oil, belts and antifreeze. Engine is reinstalled and running. Lowered the idle speed and raised the governed speed.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post
by jimmydiesel » Fri Jul 31, 2026 10:33 pm
The engine clutch on this crawler had become soaked with oil because the bell housing drain hole was plugged. The hole was plugged with a piece of a set screw that had been sheared in half. No idea where the set screw came from I believe if the drain hadn’t plugged the small main seal leak would have just drained out.
Any way its all back together and working. Got 5 hours of good pushing in on Wednesday.
Then 5 minutes before shutting down this happened. Called it a day.
It’s been at least 30 years since I had to roll a track back on, time to polish up those skills.
This dozer has manual track tensioners, the tensioner backed off easily and I was able to pull the spring out. This let the front idler retract a lot. Put a jack under the back, used the blade to lift the front. Some shoveling and prying with 5’ bars and the rail was back under the rollers. We were able to pry bar the rail most of the way back on the rear sprocket then put it in gear with the other side steering lever back and it just rolled back on. Back pushing dirt.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post
by jimmydiesel » Mon Aug 17, 2026 10:17 pm
After putting the track back on we needed to take it for a test drive.
440 ICD 831 Loader
440IC 831 Loader
