I am rebuilding a 440ic 5 speed transmission and am needing to set the correct shim up on the output shaft but the book calls for a specific tool a AM452T to give me the proper mic thickness to my ring gear. From what the book says I install this (AM452T) and subtract the number etched on the output shaft from the set tool number, I believe it is 2.275 or something I would have to look back in the book, and that gives you the mic thickness to be measured between the shaft and this tool.
Is there any other way of going about this or would getting this tool make it easier?
Lavoy, do you sell this tool?
Thanks in advance,
Ironyetty (cliff)
440 transmission output shaft alignment
- switchhappy
i just got done re-building my 440 tranny.. mine was tore apart for 2 years befor i got it.. when i put the new ring and pinon n i set up the pinon first.. i thaink i used 4 shims.. but what i did was put the ring gear n and see if the gears was comeing back to the ring far enough.. in my case the pinon was the easy part.. just be sure u put that bottom shaft n befor the pinon. but i had the hardest time with the ring gear back lash.. after taking it out about 50 times and moving shims i ended up gitting it at the lowest nember the book called for.. i figered betime the berings broke n id be n the middle.. if u have any other question i can try to help.. my tranny is working great thanks to ed at crawler hevan
Users browsing this forum: No registered users and 320 guests
