Post
by Stan Disbrow » Wed Dec 05, 2007 1:53 pm
I remember an old Cat Sixty that sat in a shed at the edge of a farm on top of a sizable hill back where I grew up. The county highway dept. owned it and it had a Vee plow on it. The road was cut thru a pass with cornfields on both sides, so the snow would drift into the cut and block the road.
The county paid the farmer to use the old Cat to push open the pass each time it snowed enough that they couldn't use their trucks to open it up. They used that poor old thing up until the late 1980's when the farmer's son finally passed on and there was no one left living on that farm to use the thing. So, the county scrapped (!) it and used a large truck-mounted snowblower to open that praticular road up.
It was sad to see the old Cat go, though. It was unique and a real landmark in that area.
BTW, I learned the trick of having wood under the tracks of a crawler when parked from this thing. The county had railroad ties in the shed for the thing to sit on so it wouldn't stick to the ground when the snow melted off the tracks.
