JD750 thru JD750C Serial Numbers
Facts and knowledgebase about John Deere crawlers
Post by Stan Disbrow » Wed Jan 30, 2008 2:20 pm
Serial number list, by year, for the JD750 through JD750C.
JD750 Straight
1976 241700 - 259282
1977 259283 - 283049
1978 283050 - 313292
1979 313293 - 331934
1980 331935 - 363140
1981 363141 - 380889
1982 380890 - 389057
1983 389058 - End
Note: There's a serial number jump here which appears to have occured across the line in 1983-4.
1984 700100 - 712039
1985 712040 - 713889
1986 713980 - End
Note: We have an overlap in serial numbers between the JD750 and JD750B in 1985 and 86.
JD750B
1985 712040 - 723454
1986 723455 - 734869
1987 734870 - 743049
1988 743050 - 753779
1989 753780 - 765169
1990 765170 - 772666
1991 737667 - 775521
1992 775522 - 782175
1993 782176 - 787642
1994 787643 - 805720
1995 805721 - End
JD750C
1994 797683 - 809307
1995 809307 - ?
Odd that the list goes no further than 1995 when it lists the JD750C as being produced from 1995 thru 1999.
The list also shows a different set of serial numbers for the straight JD750 LGP (Low Ground Pressure) from the regular straight JD750. The serial numbers for the JD750B and JD750C cover all the variations (LT, WT, LGP). Go figure.
JD750 Straight LGP
1976 242700 - 259282
1981 363141 - 367350
1982 367651 - 372160
1983 372161 - 376770
1984 376771 - 381770
1985 381771 - 389057
1986 389059 - End
The source of the data is from a farm equipment quick reference guide that's intended to assist dealers in determining the year and current market value of trade-in equipment.
The guide as such only lists the beginning serial number for each year. I'm making the reasonable presumption that the last serial number for any given year is one less than the starting serial number for the successive year.
Thanks to Digitup for sharing the relevent pages from his guide with us so we can determine what year a given machine is.
