2010 Sprockets
robotmaker
2010 Sprockets
Post by robotmaker » Mon Jun 16, 2008 9:41 am
Lavoy and all,
I found a used set of sprockets for a post 42000 JD2010 and have taken posession of them. Since I had one of mine off (pre 42000 mounted on my post 42000 crawler) I turned it upside down and laid the new ones on top of them. I can't see any measurable difference between them. So I threaded on the new rails (without installing the pads yet) and ran them around on the sprockets and do not see or feel any binding. The crawler is still up off the floor tho with no weight on the tracks. Will I see any difference in this setup after putting it back on the ground? You told me awhile back that if my pre 42000 sprockets were worn enough that they may work with these newer 1-3/4" bushing rails.
rj
JD 2010 Crawler # 42193, 6 way blade and ripper attachment
cat10til2
Post by cat10til2 » Mon Jun 16, 2008 9:43 am
glad to see you got the sprockets OK. I haven't seen to talked to Norm at all since the day I took the pics.
cat10til2
JD 1010, 610 blade, winch, gas
1968 case 530 CK, 1946 John Deere A, 1928 Ford Doodlebug, 1969 Minneapolis Moline with West forklift attachment
Post by Lavoy » Mon Jun 16, 2008 4:55 pm
Yes, if there is enough wear, they will sit in the cup. Where you might encounter a problem is as the rails wear and the pitch elongates, they may tend to climb. Then again, if the sprockets wear along with the rails, it may not bother either.
