420 tracks
bulldozerman
420 tracks
Post by bulldozerman » Mon Sep 01, 2008 7:18 pm
I found a full set of chains and pads for my dozer, the guy wants $1000 for both sides, he says that there at about 80%, is that a good price?
thanks
branden
1958 420c 5 roller
1944 Farmall A
1960 Case 440L backhoe
Post by Lavoy » Tue Sep 02, 2008 10:29 am
IF they are 80% yes, but I would highly doubt they are. I don't mean this as an accusation, but percentage wear expressed by most people is just a guess. There is a process to determine it including internal wear, external wear, rail height, and pad height.
You ask him if you will measure the length across 5 pins and give you that measurement. 23" is new, 23 1/2" is 100% worn.
CELSESSER
Post by CELSESSER » Tue Sep 02, 2008 4:57 pm
Make sure that the chain is under tension when it is measured to get a meaningful accessement. If it is not streched it could "hide" some wear.
Chuck
