Good afternoon-
A while back, I bought a 2010 parts crawler (loader) and have been working with the previous owner to arrange transportation.
One of the issues it has is according to the previous owner, the steering clutches are "frozen" (rusted); thus the crawler cannot be rolled onto a trailer. I am totally going by the descriptions given by that person as I cannot actually visit the crawler; I bought it on the cheap mainly for the good undercarriage and other new parts on crawler so the actual reason for the "frozen" situation is not all that important to me right now but is a loading and unloading issue.
As to what I have been told:
1) Crawler has sat in weather uncovered for a couple of seasons in northern Illinois
2) Crawler was placed on boards and tracks do not themselves appear to be frozen
3) Engine was rebuilt about two years ago and ran well but is now stuck (based on trying to turn crankshaft)
So I have the following questions for those in the know:
1) Am I right to assuming that stuck steering clutches wouldn't cause the crawler's inability to roll (wouldn't it just keep it from steering)?
2) Am I right to assume stuck engine has nothing to do with this condition (I would assume that cold weather disconnect lever could be pulled to make sure)?
3) Is it more likely the brake bands are stuck again the clutch housing or drums? Can they be disconnected easily?
3) Could the H-L-R in any way cause the sprockets from rolling (assuming in neutral with gear select in tow position)?
4) Any thing else I'm missing on this?
Pardon my ignorance on these things but I haven't had the opportunity to inspect or take apart myself. Ideally I would like a quick checklist of things that the previous owner could try to make the loading/unloading easier.
One last thing- the previous owner offered to spray inside clutch housings with a rust penetrator. While we usually talk about not doing this, we are at the point where I will probably have to disassemble later anyhow. If there is some specific chemical to try, I would appreciate knowing that.
Thank you for your time
Suggested Steps to Attempt "Unfreezing" 2010C
I am going to break engine loose at some point...I have some experience in that but need to get it first!
Users browsing this forum: No registered users and 103 guests
