jd440 water mixing with oil
I have replaced head gasket and checked head for cracks only crack is between the valve guides and it is verry small . Water is coming out of the exhaused pipe. and mixing with the oil in the pan does any body have any idears what could be the problum or how to find out. this is my first time on a masage board i hope that this request is o.k alan adams
alan
- JD440ICD2006
I am jumping in here without knowing which engine you are talking about, but assume it is the gas 440?
There has to be a crack somewhere if water is getting in the oil. Either the head gasket is not sealed, or there is a crack that you have not located somewhere.
Sorry I can not be of more help.
- Mark Birdeau
- 420 crawler
Just came across this post as I haven't been on the board for several months. My guess if you have water in the oil and water out the exhaust the crack between the valve guides would be a good possibility. Another place there could be a leak is around an injector if its a diesel. This I'm not sure about as I'm not familiar with the 2-53 injectors but I have seen it on larger Detroit diesels. Mark:
Water in Oil
If the engine has piston sleeves, there is a seal (sometimes an O-ring) at the bottom of the sleeve, which can leak. Also with time, the water will eat small pin-holes in the base of the sleeve through electrolysis.
My suggestion is to remove the radiator cap and insert a rubber stopper with a tire valve and gauge so the water jacket can be pressurized with compressed air. It does not take much pressure. Look for a pressure drop in the gauge or maybe a hissing sound from the crankcase filler tube.
If the leak is slow, maybe some radiator leak sealer will work. Otherwise is it tear-down time.
It could also be a headgasket problem if the head/block surface was not clean or the head torqued down properly. Both oil holes and coolant pass through the head gasket. I found a good headgasket sealer is just standard spray paint. Soak the gasket both sides, slap on the engine wet and torque it down.
Mark
Mark
JD 2010 Crawler with Loader
Users browsing this forum: No registered users and 49 guests
