350dozer
mjl1369
350dozer
Post by mjl1369 » Fri Mar 06, 2009 9:04 am
well I've learned a great deal ! with the knowledge I've gained from here and a jd service manual I'm going to pull oneside of my finaldrive today. I learned a few new cuss words trying to get the master pin from a 44 yearold track it was hell but it's done I've pulled the bull gear and I'm about to unbolt my final !!!!with no shop ! no concrete to work on is tough! well I'll keep ya posted! thanks mike
mjl1369 1965 350 dozer 1950 ford 8n used daily! various harleys and 3 ford trucks!!!!!
Post by Paul Buhler » Fri Mar 06, 2009 5:19 pm
Has it started to rain yet? :wink: good luck, you'll get it done.
mjl1369
update
Post by mjl1369 » Fri Mar 06, 2009 7:39 pm
Have the dozer in a carport! thanks for the encouragement! Well today I got the final off with some obtuse angles, bad news all the brake linkage throwout and clutch shafts all froze ,Have worked the clutch pack loose from the final lost three fibers . The entire pack was a solid mass, now I see why there are so many of these out there It take plenty of time and a serious amount of patience to get it done! well I'm tired! Tomarrow gonna take off the housing so I can take it to be sandblasted and maybe be able to save various parts of the linkage!
If anyone has any of the smaller linkage parts I'll post what I need and maybe there's someone out there with one on a shelf!!! Thanks and I'll keep on posting!!!!!!
mjl1369
well another good day!
Post by mjl1369 » Sat Mar 07, 2009 7:02 pm
I got the steering clucth housing off today loaded up the parts and was off to the machine shop! completely sand blasted the steering clutch housing inside and out ! god what rust can do to the linkage!!!!!I had the brake housing for the clutch sand blasted too to remove all the rust! sanded flat all the metal disks and rebuilt the pressure plate everything was within specs so I left well enough alone!need a few bearings and a brake band and have to hunt down that steering lever #T23625 if someone has one or knows where I can get 1 asap would be appreciated
well searching parts !!! thanks for reading
Michael J Lavender 350 1965 johndeere dozer 152 cu in gas, 6300 blade
mjl1369
waitin on parts!
Post by mjl1369 » Sun Mar 08, 2009 10:41 pm
well monday approaches I'll be calling around looking for four parts! I've found four places ,but am waitin to talk to lavoy in the am from this message board I've gained the confidence and the knowledge to fix my dozer! hell I know dozer mechanics around here but to get to my place costs$$$$$$ I figured I'm gonna own it so I better be able to fix it! I've oil bathed my housing and freed up the rest of the pins and shafts more oil more air I probably wouldn't suggest the sand blasting part but I really had no choice I just have to be very careful to make sure I get out all the sand more oil more air! keep ya posted mike
mjl1369
A long wait!!!
Post by mjl1369 » Fri Mar 13, 2009 3:38 pm
I've waited all week on parts ! 1 wrong part and have to wait 3 more days to get it here! I changed the bushing that goes to the trans case new pilot bearing!all new clutch disc's sand blasted the metla disc's, found out the height adjustment for the clutch fingers was 1.579 inches off of the brake housing so I've devised my own gage no time to wait for the gauge!adjusted and exercised the clutch fingers til the adjustment came back on all 3 the same! ready to reinstall the housing just waitin on a brake lever they sent me one for the right side different # than I ordered but such is life!!! if I got everypart of it the first time I would have been blown away! 1 part to go!!! keep ya posted !!!!!! Mike lavender 1965 350dozer 152cu.in. gas motor!!!! almost there!!!!!!!!
mjl1369
parts here!
Post by mjl1369 » Fri Mar 20, 2009 9:14 pm
well finally I'll get back to work on my dozer! I recieved the brake control lever that goes on the steering control shaft I freed up that shaft and the throwout shaft! everything is clean well greased and ready to be put back together I'll keep ya posted gonna snap some pics before I put it all back together!!!!! thanks for lookin Mike 1965 jd 350 dozer152cuin gas motor!!!!!!!!!
mjl1369
back at it!
Post by mjl1369 » Sat Mar 28, 2009 6:15 am
Haven't had much time!got the correct numbers for the throwout adjustment! got my clutch housing bolted back up! man, it was easier taking the frame bolts out then goin back in!got a new boot for the brake rod and freed up the adjuster ! My property is about 20 acres of which maybe 7 are semi flat the rest travels off to the gulley! I took the machine apart to fix but gotta have the brakes right! every part in the housing moves freely now and I'm gonna put the brake band and final back on today after I recheck it all! A little at a time ! well callin for snow ! Guess my 8n will have to do the drive! good ol ford! thanks fer lookin Mike 1965 jd350 152cuin gas motor! soon to be dozin!!!!!!!
mjl1369
I be Dozin!!!!!
Post by mjl1369 » Thu Apr 09, 2009 6:52 pm
First of all I'd like to thank this message board and all it's posters ! I've put my machine all back together with positive results! It will finally steer in both directions with the added power of both tracks powered, my property should be alot easier to clear! I got my finals back on I didnt have to do the other side she was frze up, eventually I'll do it but at this time I need my machine. I got the adjustment about dead on what a breeze it is when everything functions properly! I'm stiil workin on it I'm changing the manifolds next, The one I have is rusted through so I decided to change it out for another used 1. I appreciated being able to find answers to my questions here without having to actually be face to face !!!! Once again thanks!!! Mike Lavender 65 jd350 135cuin gas motor! and a great little machine!!!!!!
early 350
Post by mini kahuna » Fri Apr 10, 2009 8:50 pm
I have a soft spot for early 350's too,they are just a nice compact little dozer.
they are lightweight enough that they don't tear the ground up,but they push and dig really well for their size.
