440 icd throw out bearing sleve
jimmy
Post by jimmy » Tue Nov 08, 2005 1:54 pm
My sleve has a large flare on the outside end,whyis this and should I replace it or hammer it straight again?????Jim
Jimmy in NC
Post by Jimmy in NC » Tue Nov 08, 2005 2:02 pm
Jimmy-
That is from the clutch end bearing getting worn if I'm not mistaken. (I do know it's from wear and age)
I just got one for my 420c .. it wasn't that much.. I'm pretty sure less than $20.00. Personally, I'd just get a new one and know it's round and straight.
Jimmy in NC
Post by Lavoy » Tue Nov 08, 2005 4:05 pm
I assume you mean steering clutch? If so, it occurs when the throwout bearing holder gets rusty and pulls the sleeve out and jams it up against the clutch disc drive hub. It will also happen if someone has overtightened the adjusting bolt and crushed the washer enough that the bolt hits the throwout tube and pulls it out.
Straightening it is a waste of time, and as Jimmy said, they are not expensive, around $22 now.
Users browsing this forum: No registered users and 153 guests
