fixedforever
- 430 crawler
Post
by fixedforever » Sat Apr 04, 2009 5:18 pm
1010 Gas Crawler sold
2010 diesel crawler loader
townlineterry
Post
by townlineterry » Sat Apr 04, 2009 6:19 pm
Hi Andrew
Nice job on the cage, I built a four post cage. the front post I mounted on angle iron welded directly to the frame rails.
Hope your cage can be disassembled easy. To do the clutches you have to seperate the tracks, drop the rear skid plate. Remove the fenders and the drive spocket. Not a fun job.
You"ll need a service manual, the Jd number is SM2034, I'd get the Deere one, pricey, but very detailed.
I made a tool to knock the track pins out, will try to post photos, when I find them. Worked well, had both my tracks apart in a half hour.
Lavoy has all the parts you will need.
If you do a search of the site you will find several threads about clutches.
Good luck, Terry
townlineterry
Post
by townlineterry » Sat Apr 04, 2009 6:22 pm
Also notice your tracks have a lot of sag. If you need to reebuid or replace the tensioners this is the time to do it.
Terry
Pjw350
- 40C crawler
Post
by Pjw350 » Sun Apr 05, 2009 12:58 am
Hey Hey Andrew. Cage looks real good brother also your paintjob. You need to have a pic of all of your toys together with the camo paintjobs. This guy has used cases of camo paint and has truly mad his vehicles stand out.
Let me know when you figure out how to adjust the steering clutch.
Your 1010 crawler buddie Phil!
JD 1010 Loader
86 K20 Suburban w/ Plow
79 F150
04 Ram 4x4
84 K20 6.2 diesel w/ Plow
cdndozer
- 420 crawler
Post
by cdndozer » Fri Apr 17, 2009 8:26 pm
Cage looks real good.Too bad you don't live closer,wouldn't mind one like that on my machine.
