Serial# on JD 1010 crawler/loader
bomax
Post by bomax » Sat Apr 11, 2009 12:23 pm
My crawler's serial number is somewhere between 31001 and 42000, according to the parts I've needed over the years. I've had it since about 1990, and don't know what year it was built. I have never seen the serial number on it. Is there someone here that can tell me where it should be?
Post by Lavoy » Sat Apr 11, 2009 2:58 pm
RH side of the engine block, kind of below the generator.
bomax
Post by bomax » Wed Apr 15, 2009 6:26 am
Don't see it there. Is there any other likely place?
I have had reason to believe it's not the original motor.
jdemaris
Post by jdemaris » Wed Apr 15, 2009 7:36 am
bomax wrote:Don't see it there. Is there any other likely place?
Only other ID tag is for the loader itself. That is right above the dashboard. Tin plate with two rivets.
Dave T
1010 serial number
Post by Dave T » Sun Apr 19, 2009 4:09 am
Look on the top of the transmission, left front corner.
Post by Lavoy » Sun Apr 19, 2009 1:35 pm
The crawler serial number tag would be only on the engine, RH front corner.
