royboy
- 420 crawler
Post
by royboy » Wed Apr 22, 2009 7:55 am
I have a 2010 crawler ... hobby use only... last summer it started losing power after running for 10 to 15 minutes... asked around for help and was told it was most likely fuel problems (deisel) or injectors.. so changed filter and did some cleaning... still had problems... then I found water in the oil.. tried to find some one to look at it .. but no luck.. so I just decided to check it out.. head gasket looked ok.. and didn't see any cracks in the head... so what do I do next????
Not sure if I did the pictures correct..
Thanks for any help!!!
royboy
Post
by jtrichard » Wed Apr 22, 2009 12:56 pm
the sleeve seals on the bottom of the sleeves are leaking i just did the seals on mine
royboy
- 420 crawler
Post
by royboy » Mon Apr 27, 2009 8:01 pm
Thanks for the idea about sleeve seals... how did you decide it was the seal and how big a job was it to replace them???
Thanks again...
royboy
- Site Admin
Post
by Lavoy » Tue Apr 28, 2009 9:02 am
You can pull the pan on the engine and should be able to see if there is anti-freeze coming around the bottom of the sleeve. You may need to pressurize the cooling system as well.
royboy
- 420 crawler
Post
by royboy » Tue Apr 28, 2009 9:16 am
Thank you Lavoy...
I have already pulled the head ... thinking it was the gasket.. as a beginner I am not sure where to go next ??? should I pressure test the head first or presume it is the seals or a crack in the block??
Not sure it will every run again.. but having fun playing with it!!!!!!!!!
Thanks,
royboy
Stretch
Post
by Stretch » Sun May 03, 2009 5:44 am
If you have the head pulled off I would probably take it in and have it magna fluxed just to be sure.
2010C Dozer, 2010C Loader
royboy
- 420 crawler
Post
by royboy » Tue Aug 04, 2009 11:30 am
Hi.. I am back... finally got the head checked out... all is well... The shop guy also thought it was the sleve seals... Hope someone can give me some pointers on this operation and where to find parts???
Thanks again!!!
royboy
Users browsing this forum: No registered users and 54 guests
