Final drive, clutch, brake questions.
Crawlerbrad
Post by Crawlerbrad » Wed Jul 08, 2009 8:24 pm
I just got the left final drive off my 440ic. I found about an inch of slug in the bottom, with some oil. as well as the whole brake linning in little pieces. so where do i get the brake linnings and how much. and as far as the oil i know that there has to be an oil seal in the steering clutch housing? i did not really get to look at it much as i pulled it off and had to go do something. i think that my next step is to take the final drive and clean it up as well as the clutch housing. but how much will i have to spend to redo the brakes. also i noticed that when i got the crawler in the air and the tracks off, i could not turn the sprocket. the tran was in netural, and the brakes were off. also the truning levers were not pulled. what do you think that could be. i was thinking that the brakes were adjusted tight? i do know that there was a little pull or draw on the crawler when you go drive forward or backwards.
Post by NNAATZ » Thu Jul 09, 2009 7:45 am
i would replace every thing, chances are that oil got in the clutches too. even if you clean them, oil will still surface and couse them to slip. replace the seal in the trans and the final drive to be sure. the brakes can be relined by a heavy truck shop like CATCO, or bought new from lavoy. email him for prices, their not as bad as one would think. as far as it not turning, assuming it was in some working order before tare down, u are working against the the mechanical advantage of the final drive (large gear reduction, mass of components, brakes, trans, friction, ect.)
Post by Lavoy » Thu Jul 09, 2009 9:42 am
I have brake bands on hand. If you have oil in there, most likely your clutches are ruined as well. You need to find the source of the oil before putting the final back on, or you will ruin any new parts installed. Usually it is the pinion shaft seal in the final that goes bad.
CELSESSER
Post by CELSESSER » Thu Jul 09, 2009 5:20 pm
As to the sprocket not turning. Is the track still on the other side and sitting on the ground at some piont? If so, you arent going to turn the sprocket without moving the crawler with the other track. There is no differential, both driveshafts go into the ring gear carrier. The "turning levers" are what cause power differentiation. Without the stearing lever pulled to activate the clutch you were trying to turn the other side track. Even with the lever pulled, the gear reduction and weight of everything would make it turn pretty hard I would think.
As Lavoy said if there is oil in there find out where (pinion seal due to bad or loose bearing or on the other side the axle seal between the transmission and the clutch housing)Fix, replace seals ,replace clutch fibers,replace breakband and possibly throwout bearing and possibly clutch pressure plate then put it back on. Be sure that you put lock tabs on the outer quil bolts on the pinion shaft. Whoever rebuilt mine didn't and as you use it they back out therby taking the preload off the pinion bearings allowing the pinion shaft and clutch to wobble affecting clutch activation but worst I think it has stressed the pinion seal prematurely. I had to make my own locks as Lavoy didn't have any. Not hard to do.
Chuck
Crawlerbrad
Post by Crawlerbrad » Thu Jul 09, 2009 8:31 pm
hey chuck you are right. i did not think about that. that is why when you pull the steering lever it disengages the power to that track and pulls the brake. Yeah i am looking into replacing the clutches and brakes. i just need to find time to do it all. thanks everybody for the input.
Users browsing this forum: No registered users and 46 guests
