Cutting Edge
JimAnderson
Cutting Edge
Post by JimAnderson » Mon Oct 19, 2009 7:15 am
Does anyone have the JD part number for the cutting edge used on
the model 62 blade?Thanks,JimAnderson
joeturner1977
Post by joeturner1977 » Mon Oct 19, 2009 7:44 am
Cutting edge sizes:
U 10013 U is for 72"
U 10017 U is for 88"
U 10321 U is for 90"
Hope this helps...
-Joe
1958 420c w/mc60 blade
JimAnderson
Citting edges
Post by JimAnderson » Mon Oct 19, 2009 1:35 pm
Just what I needed.Thanks,Joe.
JimAnderson
gus
Post by gus » Tue Oct 20, 2009 5:06 pm
Where would one get a cutting edge for an unknown manuf blade??
Post by Lavoy » Wed Oct 21, 2009 9:27 am
Some industrial dealers, not just a Deere dealer will have access to custom made cutting edges. I had a couple of cutting edges made years ago when I worked for a Deere dealer. I do not know who they had make them, but it was an outside company that did it, not a Deere deal at all.
steelmarlin1
Post by steelmarlin1 » Thu Oct 22, 2009 5:38 pm
You can easily make yourself a new cutting edge yourself, Just visit your local steel service center. Most of them carry abrasive resistant bars in a 400 brinnell hardness. I know because we do. All you would have to do is Plasma cut the bolt holes.
Deere 420c
Deere 40c
Deere Mc
Deere 420 5 roller
Deere 40c
Deere MC
Deere 420 4 roller
Post by Lavoy » Thu Oct 22, 2009 7:29 pm
One problem is virtually all of the Deere cutting edges use a countersunk moldboard bolt, no way to cut that type of hole. The other thing would be pretty much every cutting edge after the #61 dozer blade is a double bevel reverseable edge. Plain AR steel or something like that has no bevel and would no cut very well.
steelmarlin1
Post by steelmarlin1 » Fri Oct 23, 2009 5:50 am
It actually is quite easier than Lavoy implies. With a plasma cutter you can cut the hole large enough so that a moldboard bolt is recessed which allows you to weld it in place. As far as the bevel most steel service centers have flame cutting track machines with a head that can be beveled to cut whichever angle desired along the length of the wear bar.
Deere 420 5 roller
Deere 40c
Deere MC
Deere 420 4 roller
Users browsing this forum: No registered users and 259 guests
