2010 tracks
rpk252
2010 tracks
Post by rpk252 » Wed Nov 04, 2009 1:54 pm
Does anyone know if the smaller diameter pins (1" I believe) are readily available for the 2010? If not, are tracks from any other model compatible with the 2010?
Post by Lavoy » Wed Nov 04, 2009 9:24 pm
Yes, they are available from Deere, full set of pins and bushings for a 2010 would be close to $2400. Unfortunately for right now, Deere is the only source.
1010 rails are the same, but are 3 links shorter than 2010.
Tiny Crawler
Post by Tiny Crawler » Tue Nov 17, 2009 7:34 pm
do all 2010's have 1 inch pins? and can be used on a 1010 if you loose 3 links?
Post by Lavoy » Tue Nov 17, 2009 11:38 pm
2010 after 42,000 have 1 1/8" pins, (350 rails). On the 1" pin tracks, yes, knock off 3 links and you are good to go.
