420 reverser
industrial420c
420 reverser
Post by industrial420c » Mon Dec 19, 2005 5:52 pm
is it normal for the reverser to be noisy / grumbly. it works ok and this may be normal, but it is noticably more noisy in reverse useing the reverser than useing reverse gear.anyone with a crawler with reverser please let me know if yours is similar.or not
thanks Walt
Howard Yoder
Post by Howard Yoder » Mon Dec 19, 2005 7:00 pm
You didn't say wether it is the old style reverser or the newer one but if it is the newer one check your fluid level but more than likely you have a bearing going bad.
Post by Lavoy » Mon Dec 19, 2005 9:05 pm
There doesn't seem to be any rhyme or reason to reverser noise. I have had rebuilt reversers howl, and original ones that were so quiet it is scary. Give the potential cost if there is a problem and you keep running it, I would take it apart to be safe. There are lots of little bearings and such in there that can be bad. Even if you find it is OK, it is worth the piece of mind to know that, and good to get fresh gear lube in there.
industrial420c
Post by industrial420c » Tue Dec 20, 2005 5:01 pm
thanks for the replies.i dont know what type reverser i have. my crawler is a 420 serial# 105xxx. I will check /replace the fluid asap.walt
Post by Lavoy » Tue Dec 20, 2005 5:08 pm
The only way to change the fluid in the reverser is to split the crawler and remove the reverser from the front of the transmission.
industrial420c
Post by industrial420c » Tue Dec 20, 2005 5:57 pm
that figures . i just had the crawler split a month ago. from now untill spring its only going to plow snow.and i will use reverse gear instead of the reverser. untill i get a chance to split the tractor again., bummer. walt:(
Howard Yoder
Post by Howard Yoder » Tue Dec 20, 2005 7:53 pm
have you got a long skinny lever on the right side or a short lever on the left side?
industrial420c
Post by industrial420c » Wed Dec 21, 2005 7:49 am
my crawler has the long skinny reverser handle on the right side.
Walt
Users browsing this forum: Google Adsense [Bot] and 155 guests
