Can leaking themal relief valves be replaced without completely rebuilding a single remote control valve? This is on a 58 420C. System seems to operate normally but the relief valve does leak quiet a bit.
Chuck
Carthage, NY
Were can I find two replacement relief valves if they can be replaced?
hyd remote control valve
Chuck Florence
Carthage, NY
Carthage, NY
Yes they can, push in slightly on the valve, then remove the snap ring that is above the disc that hold the valve. Pull on the valve with a pliers or whatever, and you should be able to pull the disc out. Be careful, there is a spring under the disc. If the disc is really rusted into the valve body, you may be able to turn the relief out with a wrench and not even take the disc out.
Users browsing this forum: No registered users and 54 guests
