I am reattaching my 1010 loader arms, and the shoulder pins, where the large arms attach/pivot have eccentric bosses where the arms pivot.
Does anyone know the proper position of these eccentrics?
There are two options, up and fwd, and down and back. I installed mine up and fwd figuring that was the direction of load from the hyd cylinders.[/img]
1010 loader "Shoulder Pins"
- Tiny Crawler
- 430 crawler
Lavoy is correct, They are called Eccentric Pins there should be an arrow stamped on the pin head and is a guide to the offset position.
Offset Down== Boom in lowest position
Offset Up == Boom in Highest position
Offset Rear == Maximum boom Height
Offset Front== Maximum Digging Depth
I have the procedure if you are interested in in it.
tiny..
tiny..
Users browsing this forum: No registered users and 84 guests
