350D radiator leaking
skeetertom
Just got a 350D and it has a leak from the radiator. What is involved in removing this radiator? Took a quick look before dark but was not sure how much needs to come apart. Thanks for any help
vestor_guy
skeetertom
The front shroud actually pivots on two pins at the bottom. You need to remove 3 bolts down low on each side (5/8 or 3/4 if I remember correctly) and then 4 or 5 bolts underneath that connect to the belly pan. With those out it will pivot forward out of your way and stay there safely. I did this when I pulled my radiator, no need to completely remove it. After that, as long as nothing is too rusted up, it comes out easy.
1970 350 with a 93A backhoe attachment
