After taking the reverser apart, I discovered at least 1 1/2 cups of metal parts lying around. The roller bearing inside the Spider just wasn't there at all and one clutch plate and clutch disc was missing. The Shaft must be replaced for sure as well as the Spider and Hub. I am planning on replacing the clutches and the plates. The rest of the stuff looks good and feels nice and tight. Can I get by with this or do I need to just replace everything?
Also, the shaft on the Trans is very well worn and has a lot of a "tapered end" perhaps 1 1/2 inches or so that is very visible from several feet away. I know it needs to be replaced but can I do that without removing the trans?
Thanks...
Need Some Good Opinions...350c Reverser Rebuild
Thanks,
Cuzz...
My wife says I never listen to her.... or something.
Cuzz...
Hi
I would do all the bearings in the reverser, if you had junk rolling around it probably got into all of them. Id take a good look at your pump and it might not be a bad idea to inspect your control valve too, theres alot of places for metal to hide there that can really affect performance. Id assume your transmission input shaft is the one thats messed up? If so, yes it can come out throught the shifter cover. We actually are having that discussion in another thread right now.
Guys, I agree totally with the pay me now or pay me later point of view. My biggest problem now is the outrageous prices that deere wants for their parts. I know they haven't made the 350s in a long time, but $735 for a reverser shaft seems like a mighty proud price. I would like to rebuild so I could keep the machine and know what I have but this isn't going to be cost friendly for sure. I know, there is no such thing as a cheap crawler.
Thanks,
Cuzz...
Cuzz...
Users browsing this forum: No registered users and 302 guests
