injector pump
450c
injector pump
Post by 450c » Mon Aug 01, 2011 1:59 pm
I have just rebuilt and replaced the water pump on my 450b. The job wasn't too bad and it is working well with no leaks. I did notice some diesel fuel leaking at one of the bolt conections on the injector pump. I tried to tighten it but it was quite tight. I don't want to break it off. Are there some type of gasket or seal on these bolts that can be replaced?
pump leak
Post by jtrichard » Mon Aug 01, 2011 9:46 pm
if it is one of the injector lines they use a banjo bolt and two washers just get new washers and it will be fine i bet. you can get them at a injection shop or if your not near one jd has for a price kinda like gold from them
450c
Post by 450c » Tue Aug 02, 2011 12:30 pm
That is exactly what I am talking about. I'll try some local shops.
