Willyr
Post
by Willyr » Fri Sep 09, 2011 10:20 pm
Well it is mostly together. I have run out of money and need about $200 more to get hoses and some other stuff. Right now the twist cylinder is on but dry from factory (still plugged). I may fill it with oil just to hold the blade in one position. I also need to put a rubber flap from top of blade back over the cylinder. I used it the other day and had a lot of dirt spilling over and getting in joints that dont need dirt in them.
I have been toying with the idea of hooking up some pipe and a 90 degree ball valve so I could open the valve, angle the blade, close the valve and do my work?
Trying to sell an old furnace and a cast iron radiator, no one is busting my door down for them so it may be awhile before I can finish plumbing it.
Click on pictures for larger image
Willyr on Sat Jul 21, 2012 5:11 am, edited 1 time in total.
roadbuilder
Post
by roadbuilder » Sun Sep 11, 2011 8:21 am
Hi Willyr,
I like to use hose wrap anywhere they can't be clamped down or need slack to allow for joint movement.
I use ball valves to shut off flow to thumb cylinder when using grapples. Works good, but I remove the handles so they can't be turned by brush or limbs.
Users browsing this forum: No registered users and 122 guests
