DukeofDeere
Post
by DukeofDeere » Fri Dec 09, 2011 7:54 am
I was using my 440 dozer with inside blade most of a day, parked it for 20 min. and got back on and had no hydralics to raise the blade. I added some fluid and still no go.
If I lost prime will it take some time to get it back?
And help would be appreciated.
Duke
- Site Admin
Post
by Lavoy » Fri Dec 09, 2011 8:55 am
Should go right away, that is odd. Check the suction line for any sort of crack or air leak.
DukeofDeere
Post
by DukeofDeere » Mon Dec 12, 2011 10:51 pm
Here is what I've found...
Flow of Oil from the return to reservoir,
Oil at the pressure side,
A broken spring in the relief valve, T10660 (looking for this obsolete part)
DukeofDeere
Post
by DukeofDeere » Wed Dec 14, 2011 6:40 am
Total dismantle.....
Found pieces of a magnet in the pump which broke the woodruff key on the drive shaft
$.58 later back up and running! (Minus my time.)
Back to digging.
Oh yeah
Still need a T10660 spring for the relief valve.
Any help would be appreciated.
Duke
Users browsing this forum: No registered users and 117 guests
